Questions on 99 4cyl
when i go over speed bumps it sounds like something is kinda i guess you could say ticking or a rattle. any body thinks wat it could be thanks
Front or rear part of the chassis?
If a rattle noise check the sway bar bushings-most common. Could also be the sway bar end link. If a knocking noise check the upper strut mounts. |
