Rear bench seat removal 2012 Camry
Can someone tell me how to remove the rear bench seat? I tried pulling it straight up from under the mid front but it doesn't want to come out. I didn't apply too much pressure for fear of damaging it.
I have Googled and searched, but couldn't find anything on this subject. Thanks |
Typically Camry seats are held in with a tab located on each side of the front of the seat. This tab faces down to engage a slot in the chassis floor.
Pull up the front side of the seat then feel under the seat for a tab. If found, pull the seat area of the tab(s) straight up. Once the tab(s) is free, pull the seat forward to remove. |
It will be easier to put it back in. I did it to get access to rear strut. which also require seat back removal (just bolts) and fiber board above speakers. Remove rear inside brake light first.
