Rear Wheel Hub Assembly Question
Hello All:
I have a 2003 Camry XLE 4 cyl with ABS. Ive noticed a squeal out of the left(drivers) rear wheel that ceases with braking. It also varies in intensity with side to side slight steering of the car at high speed. I'm looking at changing the rear wheel hub assembly and noted on pictures on the internet that one assembly looks as though it has a gear out the back, they call it a sensor ring. Another has an electric plug female port for the ABS hookup. Which one is correct for my car as they are both listed for ABS equiped vehicles? Also, I'm thinking of buying the Timken brand part as Ive dealt with their bearings before. Is this considered a quality assembly? Which is the best parts house to order from? Thanks: Michael PS: Cross Posted this in wheels tires hubs etc. |
ring is simply notches for ABS sensor to tell if wheel is slipping or not. sensor ring hub will fit non-ABS vehicle. but non-ABS hub is cheaper. you need to know if your vehicle is ABS equipped, which I do not doubt it is.
buy parts at NAPA. price wise, buy 2nd up from the lowest price. ask if part is brand new or re-furbished, you'll find a lot of that floating around. |
