removing rear interior trim on 1998 wagon
hi folks,
i am replacing my rear struts on my 1998 wagon. however i am having difficulty removing the interior trim to get to the top of the struts.:( i have searched the forum but cant find any "how to remove" instructions. any help is appreciated cheers and thank you Mark |
Is there a removable cover (has one fastener) on top of the strut tower?
hi folks, yes there is a cover however it is attached to the inner trim that goes around the window.
i feel a little foolish DOH!!! i removed all the left side trim, including the side bit that supports the seatbelt, accessed the top strut bolts, put the new strut in then when i went to do the other side i had a closer look and discovered i only needed to remove one piece of trim above the strut bolts, and i could get a flat spanner onto the bolts. All done thank you for answering my enquiry cheers Mark |
Good job. Live and learn.
