removing the transaxle
I got everything disconnected from the transaxle on my 89 4cylinder Camry, bolts, axles, wires and cables--everything, and I backed the transaxle off of the shims. But, it just doesnt want to come off all the way. Ive pushed and pryed, lowered and raised, but this is about as far as i can get it. Do i have to take out the bolts that connect the flywheel and the torque converter? Am I missing something, or do I just need to keep working it?
This is about as far as I can get it http://i203.photobucket.com/albums/a...e/Image047.jpg http://i203.photobucket.com/albums/a...e/Image050.jpg |
See Private Message.
Remove those torque converter bolts. Hope you have a transmission jack or a nice big piece of wood and someone to help you lower it.
hey how did u get the passenger drive shaft out of the bracket???????????????????????
In the space between the transaxle and the back of the wheel, about in the middle of the shaft, is a large C clip that secures the shaft. I took the steering knunckle and tie rod off of the passenger wheel so i could move it around, then I took off the mentioned clip, and the shaft pulled right out of the transaxle. The dirvers side though....it doesnt pull right out...its a bit#$
