Rough idle when electric fan runs
I just bought a 96 Camry with a 2.2. I noticed that when the electric fan runs, the idle is slightly rough. What would cause this? Maybe a voltage regulator? Is the regulator external to the alternator?
RE: Rough idle when electric fan runs
That's ok I was just trying to determine if itwas when the A/C was on maybe the idle-up was notworking.Does theidle drop ordoes the engine start missing? I guess the load on the Alt. could be enough to lower the idle. The voltage Reg is in the Alt. Do your headlights dim when this happens?
I don't think the headlights dim substantially. It doesn't seem like the idle drops either. I just feel some vibration in the steering wheel whereas it is pretty smooth until the fan kicks on. I don't think the vibration is from the fan though. It did seem like it could be a miss.
Usually if the alt is not putting out the correct voltage or can't keep up the headlights will dim. Can't say about the miss. I guess the draw could lower the voltage enough to the coil that if your plug wires are old it could produce a miss. Clean the battery posts andtestyour wires to start.
sstewart777
05-22-2008 07:00 PM
