Sponsored by:
Sponsored by:
spun bearing
Old 04-08-2012, 07:29 AM
abrat6917's Avatar
Default spun bearing
crank change in car ?
Old 04-08-2012, 03:16 PM
ukrkoz's Avatar
spun bearing crank change in car ?
does it make sense even to you?
lemmi guess. it's either main bearings or connecting rod bearings, if it's on "crank", which I am assuming is crankshaft.
I have done connecting rod bearings on a car twice. You drop down oil pan, remove engine head, lower pistons and undo connecting rods - then swap out bearings. same time, piston rings can be replaced. as of main bearings - maybe. If you can get to them.
jbundy321
01-06-2015 09:58 AM
camrywilder2
06-13-2010 05:44 PM
camryvol
10-19-2009 08:01 PM
E_S
06-20-2008 02:13 PM
redmartin
03-05-2008 10:03 AM
Quick Reply: spun bearing
