Sunroof Air noise
The sunroof on my 2012 camry is developing wind noise at highway speeds. I am assuming the weather-strip seal is getting old and needing replacement, does that sound right? And how hard is it to replace? Thanks for the help.
Is the sunroof fully closing?
Is the wind deflector sticking up? The glass has rubber weather strip around it. Need to remove some trim then the remove the 4 screws that attach the glass. Could be torx T25. |
Yes, the roof closes all the way and operates normally. I believe it's just the seal needs replacing. Thanks for the info, sounds pretty easy.
