Torque converter software / advice needed
Old Sep 30, 2025 | 07:52 AM
KillerB1971's Avatar
Default Torque converter software / advice needed
2014.5 Camry SE Sport 145k miles. Paid $6500. Perfect interior, everything functions. Sony Apple CarPlay. Rides / drives great except the crappy noisy tires. A few bumper dings. No underbody rust.
I've seen all the torque converter threads and this follows along. Here are my symptoms:
18 - 23 MPH hesitation. None after.
Worse at cold start
Zero issues shifting with paddles
Toyota ran VIN, no "campaigns"
1. Is there any way to find out what software version I have besides going to the dealer?
2. If I have the latest update do I:
a. Drive it and just deal with it. I paid $6500
b. Get fluid / filter changed and checked at Toyota
c. Have my mechanic change fluid / filter for $250
Also, after 1st start of the day my key fob won't work. Works just fine after work and later in the day ?????
Old Sep 30, 2025 | 09:38 PM
Which trans does the car have. There is a number on driver's side door edge sticker.
MC-10146516-9999.pdf
If the fluid has never been changed it might be a good idea to do so.
Any software updates would be done at a dealer. The dealer would have this info and any dealer performed service.
Old Oct 1, 2025 | 08:48 AM
Thanks for the TSB doc. Toyota swears there were no "campaigns" for my VIN. Assume this is a recall notice.
sticker reads: A/TM:-01A/U760E
MFD Date: 02/14
Any idea on dealer trans fluid change and software update cost ? Not replacing the torque converter at this time. The paddle shifters get me right by this with zero issues
Old Oct 1, 2025 | 06:41 PM
The TSB is not a recall. A dealer will not offer the TSB fix unless the car owner comes in and complains. The complaints fitting the criteria of the TSB. Thought Toyota reimbursed the dealer on a flat rate amount that may not offer much profit.
I don't know if a dealer will upgrade the firmware on a non-TSB basis. You might try to find out what the current software version is.
A Toyota dealer can quote you a price for trans oil change as this should be flat rate or book rate. Say $250-$300.
Have all the trans fluid changed. Don't do a flush but exchange the old fluid for new. Some 2/3rds are in the converter and does not drain out. Don't use chemicals or backwards flush. A dealer or trans shop should have a machine that gently moves the old fluid out while the new fluid replaces it.
Toyota has a color chart where they can compare the trans fluid color to the chart and get a good idea of its condition. The fluid is synthetic but is not lifetime. My opinion is 100K max on any synthetic trans fluid unless it operates at a low fluid temp. Increasing fluid temp kills fluid life. Stop/go driving and pulling a trailer.
cope242
Nov 1, 2023 02:38 PM
Snacks309
Apr 12, 2021 02:37 PM
spexarth74
Aug 19, 2010 05:47 AM
x00n
Feb 26, 2010 08:36 PM
