Trailer hitches that also fit older 92'-96' Camry
I Just bought a 95' V6 Camry, metalic navy blue. Im Loving the quality and the power! Im looking to buy a used trailer hitch so i can use a bike rack or cargo rack. I find a lot of 96'-2012 hitches for sale, but strangely nobody has 92'-96'.....Does anyone know of any newer Camry trailer hitches that also fit a 92'-95' ??
thank you so much!
thank you so much!
Trailers hitches are still made for your year of car. If looking for a used hitch the quantities purchased by Camry owners for the 92-96 years may not be enough to show up frequently on the used market.
Check out Reese, Curt, Drawtight, HiddenHitch there may be others.
A few tips.
When checking out hitches there is more then one design. Some hitch cross bars that attach to the frame go under the muffler, others on top. If going under the muffler when going into a driveway the car chassis angle to the ground may shift enough to allow the the cross bar under the muffler to scrape the road surface.
Class I and II hitches are available however would not recommend towing a trailer over 2000 lbs. The receiver size should be 1 1/2 inches, a typical size for bike and cargo racks but check it out for the items you want to use.
A few tips.
tranby
07-07-2010 04:26 PM
tranby
07-07-2010 02:02 PM
