Transmission
Has anyone had automatic transmission problems with their 2012 Camry? Several months ago the local Toyota dealer installed a new torque converter and gold magnets in my Camry's automatic transmission to correct a shifting problem: low throttle 2/3 slide. While the shifting problem has been corrected, my Camry is now exhibiting transmission slippage problems when I start the engine first thing in the morning. After idling the engine for a few minutes, the slippage issue disappears until the next morning. I am going to return my Camry to the dealer's service department and have the technician check that the proper fluid is in the transmission and the fluid level is not low. Any comments on how to deal with issue would be appreciated.
Slipping as in you rev engine (increased RPM) and car moves but only slowly?
Could this be considered a hesitation when giving the engine throttle? Engine does not rev up. Or trans is shifted into gear but does not engage for a short time? Rev engine but trans is not in gear. |
2012 Toyota Camry LE Transmission (U760E) Shudder
Please reply back to the current status of your Camry. Update the issue and post current mileage. Please also post date and times of repairs. If you go to my post you should be able to find my whole story as to what happened to me. I am posting it under 2012 Toyota U760E Transmission Shudder ALL TOYOTA OWNERS READ.
Live free or buy a new Toyota! |
