UV Dye for Detecting Leaks
What brands and models of UV dyes, lights, and glasses would you recommend to detect leaks in clutch and brake fluid? Thanks in advance
I use whatever the local auto parts store has. Many dyes work in everything from engine oil to coolant to brake fluid.
Suggest a yellow color dye that shows up better on dark surfaces. For a light, use a 120V house bulb style screw-in bulb in a can projection fixture. The fixture directs the light towards the object and shields the eyes from direct viewing of the bulb. This eliminates the need for glasses. |
thanks
