V6 camry oil leak 1996
hello i have a 1996 v6 camry that leak engine oil the problem is when i have driven the vehicle and turn the car off, engine oil leaks at the front of the engine leaving a puddle, i stripped the front of the engine down think it was the front oil seak and it is dry so is the timing belt, has anybody a clue what it could be maybe the oil pump ?
thanks |
Front as in side of engine facing the radiator or side having the timing belt.
Oil pump is behind the crank pulley and turned by the crank. The crank seal is the oil pump seal. |
okay, the front meaning the front of the engine. i can not seem to trace where is it comes from it just very wet in the area
There is not much to leak on the front of the engine.
Have you checked the oil filter, perhaps the gasket has problems, on rare occasions the thread on the filter is bad, etc. The valve covers gaskets can leak, a very common problem. The oil pump is in a large housing bolted to the side of the engine where the timing belt is. Check the gasket between the housing and block, leaking in this area has never been a problem but? |
thanks i will have another look and let you know how i go.
i will have a look on saturday |
