Water behind dash?
About a month ago, my wife's 2003 SE (2.4L and auto) started making a strange sound that seems to be coming from behind the dash. It sounds as though water is sloshing and is especially loud when accelerating from a stop. I found a post that suggested it could be a clogged A/C drain line. I inspected the drain and it looks to be clear so I'm wondering what else it could be. Any help is greatly appreciated.
Thanks, Pete |
RE: Water behind dash?
Two things to check, air in the cooling system or blocked A/C drain. Have you had coolant service lately? Do you see water dripping from A/C evaporator drain? Is the carpet on the passenger side wet? Even though drain might look clear you could have a partial blockage. It's an 03, still under warranty?
Turns out it was the coolant level. I filled the empty coolant tank and within a couple of hundred miles the air worked its way out. No more noise! I guess a small amount of air was trapped in the heater core? Thanks for your help.
Pete |
I had the same sound coming from my '03 4cyl and it turned out to be low on coolant also. I also replaced the radiator cap to make sure it was getting a good seal. I took the car to the dealer and a 3rd party and neither could diagnose it...what a joke. They were wanting to inspect the heater core.
ORIGINAL: petew Turns out it was the coolant level. I filled the empty coolant tank and within a couple of hundred miles the air worked its way out. No more noise! I guess a small amount of air was trapped in the heater core? Thanks for your help. Pete I took the car to the dealer and a 3rd party and neither could diagnose it...what a joke. They were wanting to inspect the heater core. JJ |
