weak cranking camry le
Old 09-01-2007, 10:25 PM
nuttintoaboss's Avatar
Default weak cranking camry le
my 02 camry le feels a little weak when cranking when i bought it the battery was dead and when i tried to turn it on i heard the clicking. after that i took it to a mechanic who charged th battery but it still feels weak so my questionis can this just mean i need a new battery or anything besides the battery.
Old 09-02-2007, 12:23 AM
Black95Cam's Avatar
Default RE: weak cranking camry le
did you check the batery have good connections (postitive and negative cables)?
Old 09-02-2007, 10:10 AM
yea checked it and sprayed it with corrosion cleaner but its still the same
Old 09-02-2007, 11:36 AM
Black95Cam's Avatar
did you check the chargering system with an ohm meter?
Old 09-09-2007, 10:03 AM
cali714guy's Avatar
buy a new battery
Old 09-10-2007, 06:23 AM
pedro's Avatar
It's probably the battery. A load test on the battery will confirm, but given the condition you bought it in a new battery is not much of a cost fix. If it happens more when the car is hot it could be starter. Resistance goes up with heat so a weak battery will not be able to push as well and a starter will not turn as well.
camry1999
03-19-2011 08:49 PM
jmp0126
01-23-2009 07:27 AM
01BlueGreen
08-04-2007 08:46 PM
unsub
02-07-2007 07:35 PM
Muddassir
12-07-2006 10:58 PM
Quick Reply: weak cranking camry le
