Weak passenger squirter- fix?
Old Jan 8, 2026 | 08:04 PM
Dspahn's Avatar
Default Weak passenger squirter- fix?
I have a 2007 Camry. The driver’s side wiper squirter is passable at best and the passenger side barely dribbles fluid. What’s the best fix? I don’t see fluid dripping below so I don’t think anything is leaking. Should I replace the tubing with silicon?
Old Jan 8, 2026 | 10:44 PM
Try using a pin to make sure the holes aren't blocked or partially blocked. There might just be some corrosion at the nozzle end and the needle will clean it out.
If fluid is dribbling out of the nozzle then you know the pump is working, if the pump fails, it typically stops all together.
If the needle clean out doesn't work and the nozzles need to be replaced, then they are typically pretty cheap and easy to replace.
Old Jan 9, 2026 | 04:52 AM
Dspahn's Avatar
Thanks for the reply- I’ll take a look.
ocman
Aug 11, 2021 04:38 PM
lionbird4
Jun 27, 2021 08:31 AM
rondo
May 30, 2021 03:46 AM
cm11402008
Feb 1, 2013 09:04 PM
twodogcamary
Nov 21, 2010 08:52 PM
