What does this indicator means?
I have lost my camry 2001 LE car's manual. :(
I am seeing the indicator which is equivalent to "car with some two tire" something like that which is in yellow color on left to my side of odometer. I am seeing this indication for past 2 days. What does that indication means:eek:? Does any one has any clue?[&o] If any one has any link where I can see the various indicator like gas empty fuel, wiper water empty etc like that. Where can I find the manual for camry 2001 LE?;) |
RE: What does this indicator means?
is it in between the heat and fuel gauge? is it the rear of a car with like two swervy lines behind it? Thats the slip indicator light. Does your car have traction control on it? It could indicate a problem with your traction control system or speed sensor(s).
YES its in the rear of the car with 2 swervy lines behind it.
But what does slip indicator light means? Any reference? Any reference to the list of those indicators which I can see it online and what do they mean also. Any link for manual too? |
traction control. it is reducing power to the wheels until they gain full traction once again. you're driving too hard for your tires/surface.
I understand this is an old tread but I'm searching for some answer as well.... I too have the traction control indicator light on as well as ABS indicator..... Both are on and stays on after starting the car..... I've check/inspect brake fluid level, its okay! Any suggestions on how to correct or is this a dealer item/mechanic issue?
Any suggestions are highly appreciated.... |
thats not so easy solution....you have two lights on the dash both mean a few things may need a fault code reader to sort out the confusion before throwing parts at the car |
