Will not start when hot
I have a 1992 Camry will start fine when cold be will only make a clicking sound when you try to start hot has to be jumped off.I have a new Battery,Starter and Alt.
RE: Will not start when hot
High heat equals high electrical resistance. I'd question that new starter. Next time pour water over starter when engine hot and see if it starts.
I should have said this is the second starter. It done with the old starter also
If these are re-built starters then they are notoriously poor quality. I guess could be starter relay?? I'd still use the water trick to eliminate starter, then work from there. Did you say car starts ok with jump start fromother vehicle?
Yes. starts right up
Do a load test on the battery when car is hot.
