would like to disable securikey+
Long story short.Is it possible to disable the alarm system on my wifes 2000 Camry,its been giving us trouble and after today while replacing the car battery and couldnt get transmitter to work,I just want to disable it...Thanks in advance,
note: I have the 3 button transmitter one button green (Gulf states) |
Replacing the battery on the remote may require it be reprogrammed to the wireless remote computer in the car. You can do this yourself but it requires having the procedures. Did the car come with any manual having procedures to program the remote?
You car may have the VIP RS3200 security system. If you search the internet you should find a pdf file for this system. Search under Toyota RS3200 and might add the words pdf. You should also be able to find the procedures to reprogram the remote. The car owner can change the security settings making the system less of a pain, but there does not appear to be a way to totally take the system off line. Your situation is common in the system being a pain, the remote no longer working when the battery was replaced, sometimes the remote just fails. If these is the case remotes are sold on the internet and at Ebay. |
(Post 62772)
(Post 62772)
Quote from manual "In the event that you lose your securikey transmitter,or if the transmitter fails to disarm the system due to weak or discharged batteries,the valet switch can be used to disarm the system.open the drivers door using the key."the horn will sound".Make sure the LED valet switch is in the off position (out),then turn the ignition key on.press and release the LED valet switch to the on (in)position.The system will disarm and the vehicle can now be started."end of quote. {{This procedure will not work if you disconnect the battery}},like I stated earlier I replaced the car battery and when I reconnected the ground the alarm went off and could not be disarmed via the valet switch,luckily retrieved the remote out of the spare key can.threw in a fresh battery and disarmed it.....what a pain....I would sure like to totally disable this thing Thanks toyo |
In the past found the RS3200 manual with a Google search. There does not appear to be a method of totally turning the thing off.
There is a way to turn off the passive arming. It's a Three Stooges procedure, meaning one needs to do repetitive things in a certain order within a certain time. |
Securikey+ emailed me the programming instructions and also the Installation manual if I do decide to uninstall it,helpful people there at the Gulf states Toyota,will probably keep the security system intact....thanks for the help toyo.
