96 camry dx exhaust flexpipe size?
what is the flexpipe size for factory exhaust? for a 96 camry dx 4 door
looking for inner and outer diameter and length
Best go under chassis and measure OD and length.
Have several options including weld on, slide on and clamp, and getting a new flex pipe already connected to header pipe. Then make your pick. |
messured out OD as 2 inch sound right to anyone else
and does it need to be replaced with flex pipe or could i get away with soild pipe
Take a soft tape measure and check circumference of pipe, then compute diameter.
Listings include 1 7/8, 2, 2 1/8 inch. If not wanting to weld the pipe, obtain a slide over clamp-on part such as the ones in the link below: JEGS Universal Flex Couplers - Free Shipping on All Orders @ JEGS The exhaust needs a flex pipe, a solid pipe will crack. |
this is what i was thinking of going with
94 96 Camry Converter Repair Flex Pipe Made to Repair Your Converter Flex Pipe | eBay |
Looks like it should work from what you have said. Free shipping is nice too! Have you checked out the local parts stores? Sometimes it's nice to be able to return stuff if it is not right. Be sure to check the seller's return policy and feedback.
