Failed emissions for Nox.HELP
I recently had my car fail the emissions for high level of Nox. I had the EGR valve replaced almost one year ago. I also had a transmission put in also. Is there anything I can do to get my car to past?
Year of car and engine type?
What were the actual emissions numbers? |
1992 4cylinde-2200 engine - 1220 910 1095 1006
N0x is a result of high combustion temps or failed converter.
Items to check: Engine coolant system is operating OK, engine not running hot. Engine is not running a lean mixture. No vacuum hose leaks, etc. How does the engine run? Ign timing is OK. 02 sensors working OK. Has the MPG dropped? EGR valve problems. Note: EGR system is off at engine idle. If N0x is high at idle speeds then would look at a bad converter. |
nox(ppm) failure ho to fix
i have 1992 camry w 2200 engine failed emissions test what do i do to fix
fail for NOX, on most cases is due to a inoperative EGR system , bad cat converter will do it too but cat converter will go if problem is ignored for a long period of time .
toyomoho list is also a high potential problem . the best way to determinate if egr valve work is applied vacum to it when engine is at idle, a good egr flow will shut down the engine wild doing this ,(it means egr flows ) if engine dost't shut of or a least runs very rough egr is not doing its job ,possible problems bad egr valve , clogged egr tubes .If engine shuts off on this test problem is on the activation side of the egr system ,posible problem /egr vsv ,torn or clogged egr system vacum hose ,bad vacuum modulator valve, no vacum ,ecm . |
Originally Posted by mark davis
(Post 71296)
