Rear Exhaust Intermediate Pipe Hangs Too Low From Factory
Hi Everyone,
I just bought a 2008 Toyota Camry Solara SLE V6. I noticed, like many other Camry's on the road, that when you approach these cars from the rear from inside another vehicle, you can see part of the exhaust system formed much lower to the ground than the rest of the system. It even looks like it would be proned to hitting debri in the road it is so low. I have seen at least ten Camrys like this. Is their a standard solution to this? Thank you for any help you can provide. Tom |
1 Attachment(s)
could be an after market pipe section fitted
a broken support mount or exhaust pipe section at joins needs re alignment if not a DIYer pull into an exhaust fitting shop check the image and link after market2008 solara zrst system https://www.parts.com/index.cfm?fuse...SYSTEM&Title=- |
The exhaust is low and there are no simple fixes.
Originally Posted by Solara
(Post 94805)
Hi Everyone,
I just bought a 2008 Toyota Camry Solara SLE V6. I noticed, like many other Camry's on the road, that when you approach these cars from the rear from inside another vehicle, you can see part of the exhaust system formed much lower to the ground than the rest of the system. It even looks like it would be proned to hitting debri in the road it is so low. I have seen at least ten Camrys like this. Is their a standard solution to this? Thank you for any help you can provide. Tom Thanks everyone for your feedback. Tom |
