Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Air Intake Hose
Old 09-13-2006, 02:36 PM
Kamuri's Avatar
Default Air Intake Hose
My stock intake hose cracked, I was wondering if I should get a new stock one. Are the intake hoses in 3rd gen (94-96) capatible wwith 97-2001 camrys?
Old 09-13-2006, 04:06 PM
nodrogkam's Avatar
Default RE: Air Intake Hose
i'd just get a new stock one to be on the safe side.
Old 09-14-2006, 01:11 AM
Joel_CA's Avatar
The the overall shape may be the same- there may be differences in PCV hose locations, etc. Although i forgot the year of the actual Camry- i did manage to use a replacement hose meant for another model year on it but had to modify it for the PCV fittings. Good Luck!
Joel, CA
Old 05-07-2019, 07:41 PM
dtpe's Avatar
I replaced my original air intake hose on my 96 4 cylinder Camry. I had to take it out to do some repairs and now I can't figure out where the hose I have an arrow pointing to in the attached photo connects. I've looked all over the car and cant find an open connection for it.
I can't find a place to connect this hose.
Old 05-07-2019, 11:05 PM
Look behind the engine block. May need to get under the car and look up.
Old 05-08-2019, 11:38 AM
dtpe's Avatar
Thanks. I went under the car with a flashlight. The connection is located in the front of the engine block under the exhaust manifold on the passenger side. From now on if I have to remove the air tube, I'll remove the hose from the tube and not the lower connection. Thanks again.
Old 05-08-2019, 03:56 PM
dtpe's Avatar
I stand corrected. It is in in the back. I get a little disoriented when I have to crawl around under there sometimes.
Old 05-08-2019, 04:59 PM
Good job. Thanks for posting back.
dabutt2002
11-15-2018 11:56 AM
newtoy
10-24-2016 09:30 PM
bobjohnson2121
02-09-2013 11:34 AM
Gunner Joe
07-12-2011 09:11 PM
Kamuri
05-24-2007 03:32 AM
Quick Reply: Air Intake Hose
