Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Tumor on my air intake
Old 04-13-2008, 08:48 PM
Default Tumor on my air intake
Yea, I have a 4 cyl in my 94 camry and my air intake has a box hanging down in between the filter and the throttlebody. Reading another thread someone mentioned a resonator box and removing it. Is this also a resonator box? Would it make any difference to remove this box? I've never seen it on any other vehicle I've worked on and the aftermarket intakes I've seen havent had the port to fit this box. Any insight?
Old 05-05-2008, 08:17 PM
Default RE: Tumor on my air intake
yes, that is a resonator box and it will not change your performance in any way, if you remove it. Just make sure to cap off that hole.
Old 05-06-2008, 01:51 PM
what is the best/proper way to cap the hole? Thanks
Old 05-06-2008, 11:45 PM
There may be another post on this same subject.
The box also prevents water from reaching the intake if for some reason it enters the system.
Old 05-07-2008, 12:53 AM
ive had mine off for years, never sealed the hole, never had an issue.
Old 05-07-2008, 07:32 PM
Well i wouldnt recommend leaving it exposed...Its unfiltered dirty air getting past the filter into the intake.
Old 05-08-2008, 09:39 AM
Yea I agree there, if you let that much get into your intake you might as well run it raw, no filter, you'll get just as much dirt and other residue in there to over time clog up your system. Im thinkin I'll even just keep the thing on with a plastic bag in between so the air doesnt go thru.
Im thinkin a custom intake later on, dual cone. What do you guys think? It kinda separates with a y joint so I can have 2 separate cones. Would that pose any problems? I already know it looks sweet, but will it help or hinder me?
Old 07-30-2008, 08:57 PM
Most likely, it's just a resonator box. Anyways, that resonator box thing can be a bit difficult if the vehicle isn't jacked up.
__________________________________
Powered by Autopartswarehouse.com
Kamuri
05-08-2019 04:59 PM
camracer
07-07-2008 08:32 PM
Kamuri
05-24-2007 03:32 AM
mutoy
05-21-2007 11:09 PM
v6kamree
07-27-2006 12:01 AM
Quick Reply: Tumor on my air intake
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
