12V 120W power outlet
hi!
New on forum and need some help...recently bought 12V car air compressor...Plugged it in 12V outlet and figure out that has some problems.Lost power on 12V outlet what in embedded in small department a front of the gear stick...Checked all fuses and found one burned under the dash board.Replaced with new 20A fuse but still can not get it to work...Is there any other hidden fuse somewhere in the car or under the hood...Model is Camry 2015 SE...Checked all the fuses and all of them working properly but no power on the one a front of the stick...The other one is working fine?Any of you had same problem? |
1 Attachment(s)
my only contribution to that answer
is the fuse guide of the 2015 camry Toyota Camry Electrical Fuse Replacement Guide - 2012 To 2016 Model Years - Picture Illustrated Automotive Maintenance DIY Instructions check all fuses in the engine bay ... |
Checked all of them and replaced burned one but still no power?Any other advice?
Could be a bad socket.
