2002 toyota camry 2.4l no start
Greetings. I need a lot of help, I have a 2002 camry 2.4l engine and I completely rebuilt it. I put all new, time chain, belt, gasket etc, put it in the car and it starts but does not turn on. the injectors have gasoline and the coils have a spark. What could be the problem? I really apreciate your help.
Starts but does not run?
Are you sure the cam/crank timing is correct? Is the fuel pump staying on once the engine starts? |
(Post 97909)
If the engine has spark and fuel but doesn't even try to start. Suggest rechecking the cam/crank alignment.
Also check compression. |
