2011 Camry XLE Replace Evap Filter and Canister
My Toyota dealer has indicated to me that I need the following 2 parts--#77706-07010 (Vapor Filter) and #77740-07020 (Vapor Canister). I intend to order these parts on-line, but I also need the interlocking bracket that holds the vapor filter in place, and can not locate the part # on-line. Would appreciate the part #. Thanks.
vapor filter $53 http://www.group1autoparts.com/oe-toyota/7770607010 this ad says new then used ??? $200 double check this before purchase 77740-07020-carbon-vapor-canister http://www.ecrater.com/p/24191649/to...ter-with-valve |
I need the part # for the support bracket, which is 2 interlocking parts that holds the evap filter to the auto. Thanks.
for that bracket..it will be a used one
if you cannot fabricate one yourself contact a toyota wrecker or boneyard ... take it off any 2005 plus .. toyota camry |
Has anyone tried replacing the Evap Canister and filter DIY? How do you even access it? I saw a video where they lowered the exhaust, and then slid out the canister. Any tips?
