2012 Camry SE AC Issue
I have a 2012 Camry SE with the four cylinder engine.
The AC has a strange issue. When it is turned on there is a delay in the AC actually coming on and blowing air. It might be 30 seconds it might be a minute. It will come on and blow cold air however you can here the fan motor fluctuating slightly and it makes a little noise sometimes. If you turn off the AC once it starts and turn it right back on it will typically run right away but if you wait for a minute or two you go through the delay again. Any ideas what it might be? I have replaced the actuator to no avail. Your help would be greatly appreciated. |
There is a delay in the climate system turning on or the fan blowing air or both?
