91 Camry won't start when hot
Hi all, I'm new here. I have a 91 Camry and it won't start after I runningaircondition. It just click and click, and after approx. 10-15 trying then it starts. This is the 3rd starter I replaced, the last one I bough from the dealer. I 've never have any starting problem in the morning only when it's hot, after running the airconditionning then stop or after a couple stops on the hot day. Any idea or suggestion what may be wrong with the car? Thanks
RE: 91 Camry won't start when hot
well maybe you should get a pressure check on your a/c system it can be tht you build up to much back pressure(a/c systems do build pressure)and after you stop the car the pressure stays there until 10-15 min until it releases and car starts.
Thanks for the reply.You mentioned thatthe AC built up pressure and I'm trying to thinkwhere the pressure will be? Would you mind to tell mewhere? Thanks
