92camrey overheating problems
i have a 92camrey 4cyl and have crazy overheating problems i have looked and found anyone else with same problem.i have bubbles in raidiator,water flowes out of overfill fast is that from pressure from a cracked head ,blowen gasget,crack in block the bubbles are really hot .i had the same problem with the orig.moter so i changed out the moter,and have the same problem are they known for having a bad moter for that year.what can i do i have tried all sealers even the blue devil with no luck on any of them . is there any hope i love that car thanks for any help.
If you think the issue is a blown head gasket preform a block test for exhaust gases in the coolant.
Given this is the second engine with a problem have you check the cooling system, plugged radiator, etc? Some sealants and cleaners also have effects on the radiator as in plugging it up. |
If you think the issue is a blown head gasket preform a block test for exhaust gases in the coolant. and it work... it sometimes blown gasket most of the time it's not. |
thanks I will have it checked is there any outher reason for the bubbles?
