98 camry le...help with power wire
Old 03-22-2009, 12:16 AM
Red face 98 camry le...help with power wire
i have looked over and over for a hole to run my power wire through to my amp, but the only hole that i can find is on the driver's side which is good but wen i push the wire through, nothing seems to appear, does anybody know a hole to run my wire through instead of having to drill? thanks..
Old 03-22-2009, 11:41 AM
Push a rod or section of coat hanger through first.
Old 03-22-2009, 07:00 PM
yea, thats wht i tried but the hole seems to curve or change once u get far enough in and then theres no way to bend the hanger or wire so that it keeps going.. does anyone know any other solutions or holes that may fit under the hood?
Old 03-22-2009, 09:28 PM
Have you tried pushing the rod through from the other side?
Find a location where the wires come out and insert a dull rod next to the wires. You may be catching the gromment that is pulling the rod to one side.
Old 03-22-2009, 09:51 PM
okay..i tried that but..when u try and push the rod from the inside > out it doesn't go far at all because it seems like the hole is so packed with other wires inside of it and once u push in, the hole seems to curve up or something so i can't push it any farther, the rod just stops. but i am pretty sure i have both ends to the hole, my only problem is..will it fit through both sides considering how thick my power wire is and if i can even curve the wire around the hole so i can push it through the inside.. just out of curiosity, what kind of camry do you have? do you have any similar holes in yours that may be on mine.. (98 camry le).
Synomenon
06-18-2011 07:42 AM
kingkong_1986
08-31-2009 03:33 PM
astar312
03-25-2009 05:58 PM
tik05
02-28-2006 02:48 AM
tik05
01-20-2006 08:31 PM
Quick Reply: 98 camry le...help with power wire
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
