Brakes-99 CE
Hey guys. I new to the forums and had a question about brakes. I recently redid my rear struts and drums. Afterwards I started feeling vibrations when I applied the brakes. I pulled the rotors and had them cut because of being warped. Im still feeling some vibrations in the pedal when I brake. Not as much but still some left. Any suggestions??
Did you adjust rear brake shoe clearance before putting on the drum?
Try working the emergency brake lever a few times. Should be 5-8 clicks before becoming hard to pull. Were the drums turned? In the future suggest replacing the rotors instead of them. If the rotors were actually warped turning them may only be a temporary fix before the vibration returns, say in 6 months. Where the pads also replaced? |
