Camry (2005) doors do not open/close
I have a 2005 Camry XLE, 4 Cyl. I noticed recently that all three doors, other than the driver door, do not open with the door switch. My remote stopped working a few months ago, which also did not open the other three doors. However, the door switch can close the doors but, as I said, does not open it. Also, if I open the doors manually, it automatically closes when the car is in motion, which is what it should be. I heard the dealer may charge up to $800 to fix the problem. Any help will be appreciated.
Part of a relay/fuse box burns out which can result in your symptoms.
The fix is to replace the box. However a seller on Epay is listing a bypass fix which apparently does not require replacing the box. Know nothing about the seller or product. Toyota Camry 2002 2006 Door Lock Fix 02 03 04 05 06 | eBay |
