Camry engineering oil pressure warning light flash
Hi,
My Camry car, the Engineering Oild Pressure Warning light flash some time. Then it is off. It flashed more than 20 times these two days. Any advice would be very expected and appreciated! |
What year of car, engine type and miles on car?
if that camry not that old or worn
check oil level and engine for leaks if ok replace the oil pressure sender if not the fault a independent oil pressure gauge fitted to test current readings |
