cheap ghd Fibromyalgia and Low Thyroid Function
cheap ghd Americans suffer from thyroid dysfunction. And over 500,000 new cases of thyroid disease occur each year. However, as staggering as those numbers appear, millions more go undiagnosed. It estimated that more than 10 million women have a low-grade thyroid dysfunction, which isn treated. And almost another 8 million people with low thyroid go undiagnosed. Allison K. I really felt terrible most of the time. I had no energy at all. I gained 40 pounds over the last year even though I ate very little and tried to follow my Weight Watcher program. I kept cutting my calorie intake and even started skipping meals in an attempt to lose weight. The less I ate the worse I felt. I had numerous sinus infections, which I had never had before. My hair was falling out, I had tingling pain in my hands and feet and always felt cold even in the summer. I had this constant ringing in my ears. I was depressed or anxious a good deal of the time. Every doctor I consulted said that my blood tests were normal and it must be my fibromyalgia that was causing me to feel so bad.
GHD New Wave Limited Edition something was wrong with me, but I couldn find anyone who could help me. One doctor said I had all the symptoms of low thyroid. But, the endocrinologist she referred me to, said all my tests were normal. How could my thyroid be normal when I have all the symptoms of hypothyroid? Allison story is a typical one. I routinely have new fibromyalgia and CFS patient who present with all the symptoms of hypothyroid including fatigue, headaches, dry skin, swelling, weight gain, cold hands and feet, poor memory, hair loss, hoarseness, nervousness, depression, dry skin, constipation, joint and muscle pain, and burning or tingling sensations in the hands or feet. The symptoms associated with hypothyroid are after all very similar to those of fibromyalgia and CFS. ghd australia thyroid gland is shaped like a butterfly and is located in the lower front part of your neck (just above the breastbone). The thyroid gland is responsible for secreting thyroid hormones. A hormone is a chemical substance formed in the body and carried in the bloodstream to affect another part of the body. Thyroid hormones travel through the bloodstream and help cells convert oxygen and calories to energy. Thyroid hormones control a person metabolism. Metabolism is defined as the sum of all physical and chemical changes that take place within the body; it all the energy and material transformation that occur within living cells. Every cell in the body depends on having enough thyroid hormone. If your thyroid gland becomes dysfunctional, every cell in the body suffers. This is why thyroid disorders can cause so many problems. When your thyroid gland produces too much thyroid hormone, this is known as hyperthyroid. When your thyroid doesn produce enough thyroid hormone, it's called hypothyroid. |
