Engine hung up.
Hello Camry fans! I need your help.
My Camry is a 2007 2.4L 2AZFE engine. After raising the engine to replace the belt tensioner, the engine will not come all the way down. I removed the engine mount nut on the passenger side. I don't see anything holding it up. Any ideas? My first post here. Any input will be greatly appreciated! Thanks. |
It's hard to quarterback this from over the net, but double check that nothing is under or getting pinched. Might try lifting and settling it down a couple times, maybe just not lined up.
Thanks patonium for your reply. I solved this issue yesterday. What was holding up the engine was the cv axle shaft. The u joint was in a position where it was holding up the engine. So what I did was support the engine with a jack and 2x4 on the oil pan, put the car in neutral, and turn the rotor. That freed up the engine. I had to use a long pry bar in between the cv shaft and mounting bracket to line up the hole and the stud. And I also fixed the rattling noise from the new tensioner. Just had to torque it down a little more. Do you know the torque value of that bolt? Hope this helps others who may be in similar predicament. Thanks for trying to help. I really appreciated. 👍🇺🇸
I replied to your other post, but I'm still happy you got it squared away!
Thanks Patonium, really appreciate your input. It's interesting that you and I have the same 2007 Camry with a 2AZ-FE and also share the same enthusiasm. I also have a small collection. I'm into surplus mainly but of course have modern stuff as well 😉. Talk to you soon!
Again, thanks for sharing and I appreciate the sharing of the same enthusiasm! I'm pretty much open to all facets there, old or new!
Confession here, (I'm going to post this as well) I have recently purchased a new Camry which is a 2012 SE with V6. Don't get me wrong, I'm still about the ''07 Camry!!!! And, '07 will always have a place in my heart. Save travels my friend! |
