HELP Door won't open
Old 05-14-2019, 07:18 PM
Andrew Nichols's Avatar
Default HELP Door won't open
Hello i have a 2000 Toyota Camry CE. I just replaced my drivers door handle, now the door wont open.
Old 05-15-2019, 04:06 PM
Did you connect the rods to the handle?
Suggest you take the car to an auto locksmith service. Once the door is open take off the door panel before closing it again.
Old 05-16-2019, 08:02 AM
I did connect the rods to the handle.
The door panel is still off the car.
The car is not street legal and i dont have a way of taking it anywhere.
Old 05-16-2019, 09:00 PM
Find the rod that works the door lock mechanism. Determine if the lock is stuck between on and off.
Old 02-12-2020, 07:22 AM
SaminaCotzier's Avatar
Door panel can't get removed easily so its vital to take help from an auto locksmith to remove the panel.
Old 05-16-2020, 08:00 AM
HaileyWilliams's Avatar
Replace the rod, may be the problem must be there or hire locksmith to help you.
Old 09-08-2020, 09:40 AM
LawrenceSimmerman's Avatar
Call that mechanic who has done the replacement or try contacting an auto locksmith for that issue.
Old 05-25-2021, 07:33 AM
CarlAnderson's Avatar
You should think of replacing the solenoid the issue must be there and this work can be done by locksmith at cheap.
Old 07-16-2021, 11:38 AM
FaithTerry's Avatar
The first step to fixing your lock is to know exactly what mechanism is causing the problem. The second step is to observe responses by your locksmith. The third step is to repeat these steps until you have found the root cause of the unlocking problem. And are satisfied that there is no repeat behavior or an apparent reason for the re-lock causing future damage to your property or person. In this situation, I decided to contact my locksmith from Utah Range Rover Key Locksmith that resolved this problem for me in 30 minutes.
sgg88
07-22-2021 06:09 PM
erbrian
03-14-2019 09:57 PM
Cardboard
04-07-2018 11:20 PM
Hippy_Joe
09-18-2009 04:17 PM
toyoman1985
07-26-2009 12:31 PM
Quick Reply: HELP Door won't open
