Help with spark plug tubes on 2012 Camry
I need help trying to remove a spark plug tube from a 2012 Toyota Camry se 2.5L
The tubes are pressed in.
Why do you want to remove them? |
(Post 97248)
There is most likely a tool to pull them out but can't find it.
Before you attempt anything. Suggest obtaining a replacement tube as could damage the current one when removing it. Toyota doesn't list the tube. Might try sealing the tube you have. This by cleaning the area around the tube with spray solvent and a tooth brush, then allowing to dry. Then apply a suitable epoxy around the circumference of the tube were it meets the head. |
(Post 97256)
