Need help with wheel size!!!
I have an 2016 camry se. I just recently purchased eibach lowering springs(about 1.5 inch drop) I am wanting to put some 19 x 8.5 wheel on there. I would like them to be tucked right on the inside fender. What would be the best offset and tire size to go without any rubbing or any other possible damage????? Thank you....
Lowering springs have a height range they will lower a car. They are not always spot on at lowering a car say 1.5 inches.
Suggest you install the springs, inflate tires to the proper pressure then measure what clearances you have. From here use an online calculator. The calculator will provide the tire location changes based on tire/rim size and offset. |
