power steering leak
2005 v6 camry power steering leak so I took of the the gravity feed line from bottle thinking it was the banjo bolt which I undid then twigged uit was the not that line so undid the gravity/suction line and replaced when I started putting it back together found a a small round hollow tube on ground not sure which end it came from so put it on bottom suction hose,and pump squals a bit now or is it a spacer in the banjon bolt.
Many Thanks for help on this. |
Photo or better description of tube.
ok got pic its hollow and was laying on the ground unsure if tis part of it but looks like it.
https://cimg4.ibsrv.net/gimg/www.cam...3e1adc7755.jpg |
Doesn't suction hose just push onto reservoir? You then installed the tube inside the suction hose?
Yes and the power squualed a bit and I removed that piece, could it be from the other end as a spacer around the banjo bolt line end, both ends were off together.
Steve |
Determine if the spacer is part of some clamp holding system for a power steering hose.
Turn steering wheel stop to stop to bleed air from the system. |
