Question on auto headlight setting
Hi all. Just bought a 2018 Camry LE. I liked it very much, but there was a question about setting the automatic headlights. Once it is set to automatic and the butt is pushed forward, as in high beam mode, these headlights should dim when the outside lights are bright enough or an oncoming vehicle is approaching. Is it something only available on one of the other models?
thanks in advance for your answers and it's nice to be part of the forum. Thank you Lance |
Is the headlight switch set to high beam
From other care with this feature I have driven, you just turn on the feature for auto high beams and it does all the work for you. No need to switch on the high beams manually via the stock/switch whatever you want to call it.
