Snickel Fritz |
06-12-2009 02:18 AM |
Hi, Kim! Yes, I have in fact replaced my entire radiator in my 95, 4 cylinder. On mine, the plug was on the bottom driver's side, and it is also called a "draincock", which is removed by simply twisting it, and is made of white plastic. By any chance are you attempting to flush out "Stop Leak", or another brownish substance? I'm curious because a flush may not be the proper solution, depending on the level of contamination. I'll check back as often as possible to help if I can.
