Rear window washer pump.
Hello forum members, could someone please help with trying to offer clues as to why my '95 Camry LE rear window washer isn't working.
The front works fine and sprays well, the rear wipers work well too but no washer solution sprays out. I cannot locate where the pump or pumps might be...for front and rear. The two small lengths of rubber tubing that come from inside the rear window / hatch seem in tact and supple...plus the two holes are free and not clogged on the sprayer. Thank you for any help. |
The car may share the same reservoir and have its own pump located near the front washer pump in the engine compartment..
Thanks for replying however I can't see where the front pump is either. it is nowhere near the filler compartment / reservoir under the hood on the passenger side and the plastic reservoir I removed and there's nothing attached. YouTube suggests it is behind the fender lining on the front passenger wheel. May need to look there tomorrow.
Thank you. |
Most of the reservoir and the pump is under the frame You will need to go underneath the area where the reservoir filler neck extends out of the frame.
Thank, will do that tomorrow.
..Thanks again, are both pumps there and how do I determine which is the front and which is the back?
Operate the front washer and the non-working pump will be the one you want.
Thank you very much.
