U140E 2002-2003 5 and 7 Solenoid Transmission
Good Evening,
These VINS are from a 2002 XLE and 2003 LE Camry both vehicles had the same Transmission a U140E stamped on them. 4T1BF32K62U539091 -2002 Pulled from Car -5 solenoids 4T1BF32KX3U061551 -2003 obtained for swap - 7 Solenoids My question specifically is since they are technically both 4 speed automatics can I pull the lower valve body off the 2002 and put it on the 2003? The bolt pattern and everything else looks right! When I picked up the transmission the only thing I didn't noticed was the main connector being different and I cant take it back. So I search all of the documents related to the U140E and couldn't find a 7 solenoid lower associated with it. I am assuming it was an upgrade for that year change to the transmission? I have looked at the rebuild parts and everything I have seen for the U140E seem to be the same. Any guidance from someone who has worked on these would be much appreciated. Thank you. |
The U140E is a 4-speed and has 4 solenoids.
Speculate the 7 solenoid trans is not a U140E, but something else and a 5 speed. For 2002 and 2003 both 4 and 5 speeds are listed. Does the 7 solenoid valve body also have vertical solenoids in addition to the ones that go into the side? |
