mycarcamry |
02-24-2013 06:39 PM |
2007 Camry Squeaking Noise Coming From Belt Area
Help! I'm hoping someone else has had this issue and knows what to do. I have a squeaking noise coming from the area where the alternator and such are. At first I thought it was just that the belt needed changing. Took it to the dealership to have them check it out. Had them change the belt as well. They said that wasn't the problem and to bring it back for them to check further. Brought it back because it needed some more work. They did the other work but didn't get around to checking the squeaking noise out (BTW, my local dealer sucks just for the record). Not wanting to go thru the trouble of making another appointment and waiting hours to bring it to them again, I took it to three different shops, Good Year, Sears and Midas. Good Year said and Sears said it's probably the pulleys and the squeaking was nothing to worry about (but they could replace them all for about $200. Midas checked a little more thoroughly and said the pulleys are fine and that the noise is coming from the AC compressor. Mechanic said there's nothing to be concerned about safety wise or that the car would break down because of it. But at times the squeak gets loud and it's starting to drive me crazy! Midas said I would probably have to have the compressor replaced to get rid of the noise. I'm trying to avoid this as it is costly and my AC works fine. Has anyone had this problem and have had a better solution? Suggestions?
