How to Convert MTS/M2TS to Quicktime on Mac
For Mac users, Quicktime is the most commonly used media player. For Sony, Panasonic or Canon, etc camcoder users, MTS/MT2S is the most common video format. However, for a Mac camcoder user, problem is coming. You are unable to directly load the MTS/M2TS files and play them on Quicktime. What should we do?
Don't worry! Video Converter for Mac will help you convert
MTS to Quicktime so that you can enjoy your camcoder recorded videos on your mac OS smoothly. With this powerful program, you can also convert other video and audio formats like AVI, MOV, MKV, VOB, etc at ease. Various video editing tools can make your output videos more impressive. You can crop and trim videos, merge serveral videos into one, add watermarks, load subtitles and so on.
Note: Following guide will teach you how to convert MTS/M2TS files to Quicktime on Mac in details. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
How to make MTS/M2TS to Quicktime conversion on Mac?
Freely download the program and try to use the trial version step by step as below.
buy video converter mac download video converter mac
Step1. Load files
Launch this MTS/M2TS to Quicktime Converter. You can click "File" item on the tool bar to load files or simply drag files in. For users' convenience, batch conversion is supported.
mac video converter main interface
Step 2. Edit video
Before MTS/M2TS to Quicktime conversion, you can edit the video with its customized features. Just click the edit icon, video editions such as trimming, cropping, video adjustment, subtitle, watermark can be finished on one interface.
mac video converter edit interface
Step 3. Select the correct output format
In the "Format" list of the "Output Setting" menu, you have a wide option for the output formats. If you need to convert MTS/M2TS to Quicktime, you should select MOV as the destination format. (MOV is the file extension for Quicktime)
mac video converter mts to quicktime output format interface
Step 4. Start MTS/M2TS to Quicktime conversion on Mac
Click ''Convert'' icon, all the task will begin with high efficiency.
Tips on MTS/M2TS to Quicktime Converter:
1. You can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the "Output Setting" menu to make the output video better. If no need, you can just keep the default parameters.
2. If you make batch conversion, you can set the "After conversion" mode on the conversion interface. It provides you "Put computer to sleep", "Shut down my computer" and "Do nothing" three mode options.
Step1. Load files
Step 2. Edit video
