Sights n Sounds Post your video clips here.
2018 Camry SE amp/sub install
Old 07-18-2018, 07:33 AM
sheltoncox's Avatar
Default 2018 Camry SE amp/sub install
I know on the XSE/XLE, there is a stock sub and upgrade to the entire sound system. I have the SE, and am wondering if the stock head unit has RCA outputs? If not, does anyone know of any plug and play wiring harnesses made for the 2018 camrys that I could use to install an amp/sub?
Old 07-20-2018, 01:16 PM
Check into line output converters. They wire directly to the speaker wiring and convert to the signal to RCA for use with another amp.
Old 07-27-2018, 03:50 PM
Caseyoram's Avatar
Default Speaker wire colors for loc
This is right from Toyota
Old 07-30-2018, 11:44 AM
A line converter can tap directly into the LA-G/LA-R etc, wires. The converter reduces their signal strength and outputs it via a RCA plug.
Some amps have two inputs sources, a RCA and a line input. In this case can connect the speaker wires directly to the line input of the amp.
Do some research on amps. Crutchfield.com is a good source.
Old 12-23-2018, 09:37 PM
CrusinAtlanta's Avatar
Default Yes you can install subs
I installed aftermarket amp and sub on my 2018 se [img]blob:https://www.camryforums.com/9d02a267-1798-455c-a25f-a1513d65f9e5[/img]
jlgutierrez85
06-12-2022 11:37 AM
Ricky Averhart
09-22-2019 11:36 AM
Cody Baker
03-29-2019 05:37 AM
RileyJSchmidt
08-17-2014 11:52 AM
xNOxSK1LLZx
02-24-2009 10:38 AM
Quick Reply: 2018 Camry SE amp/sub install
