Sights n Sounds Post your video clips here.
Engine noise 1998 Camry V6
Old 03-01-2017, 08:28 PM
Todd Harper's Avatar
Default Engine noise 1998 Camry V6
I have a strange engine noise that is dependent to RPM's, but only occurs when I turn the heater blower on. The sound comes from the engine compartment not under the dash. As soon as I turn the heater on it sounds like I am over revving the engine. Anyone have any ideas?
Old 03-02-2017, 11:34 AM
Is the engine RPM increasing when this happens?
Find a length of hose to use as a stethoscope. Then track down the location of the noise.
There is nothing in then engine compartment related to the the heater blower. The blower is located under the passengers side of the dash behind and below the glove box.
Old 03-02-2017, 01:31 PM
The noise only happens when I turn the fan on. The sound increases when I press the accelerator down, but if I turn the fan off the sound goes away.
Old 03-02-2017, 09:04 PM
dirty hands's Avatar
till something fails . these types of noises hard to narrow down
could be a voltage drop off at the battery or alternator
air con compressor clutch /blower motor/ fan speed relay ?
OldFox
10-12-2012 07:28 PM
mkv_camry
10-15-2011 11:10 PM
96camman
01-16-2011 04:32 PM
khays
07-06-2008 09:51 PM
lavalleemike
05-06-2006 03:21 AM
Quick Reply: Engine noise 1998 Camry V6
