DASHBOARD LIGHT
hi i am newbie to this forum
recently i bought toyota camry 98 model. I found a problem here. An "orange car symbol with back lights on" is appearing in my dashboard when i drive. what it means? i checked all the back lights everything is gud. Could you pls post me your suggestions? what should i do? |
RE: DASHBOARD LIGHT
The light is supposed to mean a tail or brake light is out, however other issues could cause the light to come on including a bad sensor unit.
This problem has come up a least twice recently in the last month. Review the past CF posts on the subject of tail and brake lights, etc and you will be up to speed on what to check and howto fix it. When reviewing posts make sure you look down at the bottom of the screen as you may find related posts listed. |
it also happen to me but my when my car just stop running.i would turn key and the same light will go on. to me it was the crank sensor wire got cut with alternator belt.check crank sensor.
Same thing happened with me also.
