Popcorn Thud Noise from Passenger Front Side
Hi all,
For a while I've been driving around with a sporadic thud noise anytime I drive above 60 mph. It sounds like it is coming from the tire well but honestly could be under the hood on that side. It isn't the sway bar or bearings, could be the strut but I don't think it is. It is not a humming sound. If I had to relate it to something it sounds like a rubber ball bouncing around in my tire well. The popcorn noise is due to the sporadic noise it's not a steady thud it's random but at the consistency of popcorn popping. I checked all the plastic trim around the tire well for looseness and possible banging and nothing. My heat guard for the exhaust was detached on one side so I fixed that and that wasn't it. I'm beyond frustrated but can't think of what else it could be. Anything could help! |
this member has a sense of humor
its a posted in sight and sound hahahah :) a front end noise issue you can hear but not see possibles loose wheel nuts worn or faulty tyre/tread leaky soft shock strut top strut bearing and rubber retainer loose /weak strut spring lower ball joint tie rod end worn outer CV joints do pop check lower control arm bushes if it was growling would be wheel bearing |
